LM7 conversion - Oil pan
I tried searching for this, what seems like a very obvious item, on the forums, but not a thing. I'm assuming I don't know how to use the search feature....anyways...
I have a LM7 that I've slowly been putting parts on to bring the size down so it will fit under the hood =p The oil pan is whats in question. Will the oil pan from a 04-06 GTO (LS1,LS2) work for this conversion?
Appreciate any and all help. Thanks!
tmscaf- Posts : 1
Re: LM7 conversion - Oil pan
Welcome!
No stock oil pans have worked without custom crossmembers and/or engine mounts. You need a modified oil pan made especially for our cars... Go here and scroll down a bit.
http://www.texasperformanceconcepts.com/LS1Conversionparts.html
The search feature works better when you use the google search under advanced search feature.
I'm in the same boat. LM7 swap. Can anybody confirm that the dimensions described in the 944V8 wiki manual needed to modify a Moroso as a base are valid?
http://944hybrids.pbworks.com/w/file/23370642/Moroso%2020140%20Oil%20Pan%20Modifications.jpg
I've tried using the advanced search function (Google checked) and I'm not finding any specific info
or a drawing/schematic. Anyone have? Or anyone have a better drawing/plan/different oil pan to modify?
Want to save some bucks and fabricate myself.
Thanks!
Thanks!
Jasonscottw- Posts : 125
Scroll down 3-4 rows down.Jasonscottw wrote:I've tried using the advanced search function (Google checked) and I'm not finding any specific info
https://944hybrids.forumotion.com/gallery/Personal-album-of-xschop-cat_u11.htm
Cheers!
That's what I'm looking for!
Yesterday at 9:56 am by ndog52
