Another Radiator Option
I figured I would share another radiator option that I found for these swaps: Afco 80128N. It is 23" wide and 15" tall, and as of this post, is $380. There is no cap that needs to be plugged, and it only requires spacing the radiator mount down to fit. One thing I will say is that if you are using an electric water pump, at least a Jegs version, then you will have fitment issues. Going with a remote electric water pump or leaning the radiator would need to happen.
MuhThugga- Posts : 15
Re: Another Radiator Option
Here are the part numbers for the hoses I wound up using:
Upper
Lower
Upper
- Gates 22652 (Trimmed)
- Dayco 81141
- ICT Billet AN627-21A
Lower
- Dayco 81071
- Filler Neck Supply 3244
- Dayco E72359 (Trimmed)
lower outlet
How did you plumb the lower outlet with a 90 to face up like the lt1 hoses are run? And did you add a drain bung somewhere?
nphd2000- Posts : 26
nphd2000 wrote:How did you plumb the lower outlet with a 90 to face up like the lt1 hoses are run? And did you add a drain bung somewhere?
I did not add a drain bung. If I need to drain, I'll just disconnect the lower hose.
nphd2000 likes this post
raditor
Thanks for the info. I'll probably give it a shot...car is just sitting now and $1,800.00 for a radiator aint gonna happen...LOL There is a local welder that I may pay a visit and see about welding a 90 on the lower and installing a drain.
Nice find. Thanks for sharing.
Yesterday at 8:32 am by Rob44
