Sanderson headers keep cracking
The Sanderson headers on my LT1 948 keep cracking. Both sides have been welded several times before, and one has now just cracked again.
What is a better solution for one of these old LT1 engines? I'm using this car as a daily driver, and need a more reliable solution.
Rob
Rob
Rob44- Posts : 38
headers cracking
do you have flex joints at any point after the header?
i remember reading posts eons back when i first entered my journey on the build and then didn't do anything for a decade that having flex joints is an absolute must or you will end up having the weight of the downstream exhaust putting excessive force on the header and ultimately crack.
Not sure if already knew this and already have flex joints but if you don't i would definitely look at that first thing.
Gutterboy- Posts : 230
Re: Sanderson headers keep cracking
Thanks. Yes, I do have flex joints after each manifold in the Y-pipe. I've done some reading and it looks like these Sanderson headers are just cheaply made and bound to crack again and again.
I'm going to look into replacing them with some Patriot Tight Tuck headers.
Rob44- Posts : 38
I had the same issues over the years, even with flex joints. I have some long/mid tube headers for an LT swapped 944. These were made by Texas Performance Concepts at my request, some years ago. I am not using them as i have gone to an LS engine.
PM me with your mobile number and I can share some pictures. I would sell them, if you are interested.
Rob44 wrote:Thanks. Yes, I do have flex joints after each manifold in the Y-pipe. I've done some reading and it looks like these Sanderson headers are just cheaply made and bound to crack again and again.
948 wrote:I had the same issues over the years, even with flex joints. I have some long/mid tube headers for an LT swapped 944. These were made by Texas Performance Concepts at my request, some years ago. I am not using them as i have gone to an LS engine.
PM me with your mobile number and I can share some pictures. I would sell them, if you are interested.Rob44 wrote:Thanks. Yes, I do have flex joints after each manifold in the Y-pipe. I've done some reading and it looks like these Sanderson headers are just cheaply made and bound to crack again and again.
I would be interested in these headers. I have the Sandersons and they've never really impressed me.
MuhThugga- Posts : 15
» Turbo Transaxle wanted
