Does this give anyone Idea's?
+2
6 posters
Re: Does this give anyone Idea's?
That's a great idea, but it has the same problem as all of my ideas! That's where the headlights and headlight bar go.
I'm probably going to go the route of the nice fiberglass buckets listed on this site. I'm curious if the covers are still a work in progress, anyone know?
they will be ready by the end of the week, the buckets will have an update to them also.
Awesome!
And the price will become $300 for the buckets and the covers as a combination, right?
Porch wrote:That's a great idea, but it has the same problem as all of my ideas! That's where the headlights and headlight bar go.
Headlight Bar? Whats that? It's been so long since my car has had those.
Dawgz83948- Posts : 603
What setup do you have, Dawgz?
Porch wrote:What setup do you have, Dawgz?
I have the GT racing buckets, I wish I knew other people were going to make them, because the GT racing buckets suck out loud (fitment). I installed HID bulbs with hi/low capability (HID on both), it's a great setup very bright.
Cool! Yup, that's the direction i'm headed. Do you have pictures?
Porch wrote:Cool! Yup, that's the direction i'm headed. Do you have pictures?
No pictures, but what exactly do you want pictures of? I can take some and post.
I was mainly wondering how they looked
I'm curious whether to paint them the body color or leave them black. I'm also kinda curious how the projectors look in them. Anyways, no rush...i'm just curious how they look!
Porch wrote:I was mainly wondering how they looked
I don't have projectors. I like the way they look, but the GT-Racing ones showed too much of the actual lens. So I cut Black Vinyl and framed it and I think it looks a lot nicer now. These are all old pics before the vinyl treatment.
I agree, the GT Racing buckets are not good. I spent about 8 hours reshapimg mine. And the covers don't fit very well either. I broke one and mow am going to make my own covers. I had planned to have them done but haven't gotten that far yet. I have an oven built and started on the molds for the vacuum form but have gotten side tracked with the underside of the car.
v8carreragts- Posts : 332
That does look good!! Nice work!
I was just trying to picture it in my head and i wasn't quite sure how they were going to look...
Once I get the bugs worked out of the mechanical stuff...
My plans for the headlights are to edit the existing ones to raise up as little as possible from closed position, and use multiple small lights, in a row, that just barely peek out. If I get real enterprising, perhaps an LED row such as found in newer BMW and AUDI models.
And tuck a couple of these in place of each of the big round lights.
endrnet- Posts : 129
headlights
i have been working on my headlight problem and have came up with the idea of using 2 headlight motors to replace the normal setup wich is in the way .i personly like automatic headlight feature on the car that it came with .when complete i will post some pics and how i did it.i presently have 2 headlight motors the original and one from a donor.i have also toyed around with the idea of some small pnumatic air cylinders that i have using engine vacum.
stu wright- Posts : 312
There were some instructions on how to do do the dual-motor conversion on PHB. It's not a bad option, honestly!
I don't know if you've seen, but Deutsch Nine (i think) has a setup like that and i love the way it looks! The kit is expensive though...more expensive than just using the buckets. If you get it to work i'd like to see how it's done! I know the 240 guys do the same thing to their headlights to give it the "sleepy eyes" look.endrnet wrote:Once I get the bugs worked out of the mechanical stuff...
dual headlightmotors
i dont think it would be very hard at all ive already mocked up where the left side motor will be mounted just got to wire it up to see how it works.defenitly plenty of room for mounting.late model corvette accuaters are more compact than the porsche design a thought that i have also considerd .
You might want to look at the 924 turbo headlight motor. It is made to mount on the other side. It is basically a mirror image of the one on the 944 and it mounts on the other side.
very hepful idea ill check into it .trying to find one will be the hard partv8carreragts wrote:You might want to look at the 924 turbo headlight motor. It is made to mount on the other side. It is basically a mirror image of the one on the 944 and it mounts on the other side.
found one right away thank you friend found several as a matter of factstuart f. wright wrote:very hepful idea ill check into it .trying to find one will be the hard partv8carreragts wrote:You might want to look at the 924 turbo headlight motor. It is made to mount on the other side. It is basically a mirror image of the one on the 944 and it mounts on the other side.
