Cereal bowl plate
Cereal bowl plate
I'm looking for a brake cereal bowl drawing or tracing (to scale) to make the firewall plate. I am trying to collect as many parts/pieces as I can before I take my 944 apart. TIA
nphd2000- Posts : 26
Re: Cereal bowl plate
For what it's worth, below is a diagram from Greg Sloan's conversion manual which is no longer available and in most cases, superseded by advances developed on this forum.
Use with caution and continue your search for a current rendition. Texas Performance Concepts comes to mind as they offer a power brake booster conversion kit for use with the Ford hydro boost and they make their own adapter plate.
There are others on this forum with machine shops that could also help you. Give it some time and you'll get more responses.
Kudos for forward thinking before you start. There are many details to address!!
Raymond-P- Posts : 385
» Hydroboost mounting plate
» BOOSTER DELETE
» Help with pressure plate (SPEC pressure plate doesnt fit!!)
» BOOSTER DELETE
» Turbo Transaxle wanted
