hard clutch
hard clutch
hello everyone,
well ive been driving the car for a while now and noticed that the clutch is hard to press down. i mean its a leg work out...lol. all seems good no leaks engage and disengaged when its supposed to, no weird noises. etc.
I'm using a mustang hydroboost with the stock power steering pump.
i just finished rebuilding anotheronw. this is an 85.5 NA but I put the turbo engine that came out during the ls swap, and the clutch is way soft on this one.
any ideas on how I can soften up the clutch on the ls swap one?
thanks
thanks
smkn951- Posts : 60
Re: hard clutch
what clutch master cylinder are you running on the ls swapped car? what clutch? are you still running the overcenter spring on the clutch pedal?
Re: hard clutch
I got the clutch master cylinder from TPC along with the clutch kit.
is the overcenter spring on the clutch pedal the one that aids it in retuning to the up position? if so, then its a yes it's still connected.
smkn951- Posts : 60
Re: hard clutch
Assuming nothing is wrong in the whole system, the pedal force required has to do with the ratio of slave cylinder volume to master cylinder volume along with the level arm of the pedal. To make it softer you either need a smaller slave cylinder or a longer pedal arm. Maybe re-drilling the clevis point on the clutch arm? Or going back to a 3/4" master, TPC's is 7/8", although on some cars 3/4" is not enough to release the clutch fully when depressed.
For what it's worth, my clutch is a monster too. But so are my un-boosted brakes!
smkn951 likes this post
» Selling off my stock clutch parts and RH clutch disc
» Wilwood clutch master died WAY too soon!
» Two LSx swap questions, clutch replacement and working space
