Mopar disk OK or not?
I think it's well established that the Mopar clutch disk splines, although the same diameter and count, have a different spline profile, and are a slightly looser fit on the 944 torque tube shaft. What's not clear is....Will the Mopar disk work OK? Have folks used the Mopar disk with good results?
comments??
Gord.
comments??
Gord.
murrayg- Posts : 105
gwistrup likes this post
Re: Mopar disk OK or not?
I've had a Mopar disk for 10 years now.... however, I haven't had a chance to see the condition of the splines on the torque tube....
Here is some information on the clutch splines.
There are 2 23 spline types. 23 US (Mopar)and 23 Metric (Porsche original)
The Mopar clutch disc are what has been used for these swaps forever.
SPEC makes the 23 spline metric.
2 items on the 23 spline US clutch disc.
1. When looking for a Mopar clutch disc, try and find the tallest spline sleeve. This gives you more material on the shaft. The picture below shows a SPEC, and 2 Mopar clutch disc, you can see the difference in the height of the spline sleeve.
Tall SACHS BBD4163 mopar, SPEC Stage 1, ?Mopar low spline sleeve
2. On the flywheel side there can be a small nub around the spline hole. That needs to be removed. See the picture below.
