Clutch disk type?
Page 1 of 1 • Share •
Clutch disk type?
Wich type of a clutch disk do you guys use?
I bought my conversion kit from Greg Sloan (and haven't received all yet, 14months after payment was sent). I'm starting to work on ym car and get some informations about this project.
About the clutch... Do you use standard ls1 clutch pressure plate? And wich type of clutch disk?
Gudmundur Geir ...
Gudmundur Geir ...
GudmundurGeir- Posts : 45
Re: Clutch disk type?
I was about to open my own thread asking a similar thing. I'm not looking to thread-jack you, but it'll be less messy if we bundle our clutch questions in 1 spot for the gurus.
I got the RH clutch disc from aixgelo78, but don't have a pressure plate or flywheel to go with it. Not even sure (exactly) what the requirements are. Wiki says LS2/LS3/LS7 GM#12571611 or the Mcleod conversion. Both these options seem to be boku bucks.
I don't want to doubt you guys, or the wiki. I just want to make sure I can't spend less bucks. Can I use the stock GM P.Plate and Flywheel from an LS1/T56 fbody or vette with the RH clutch disc?
adam7e- Posts : 63
I am using a stage one Spec clutch kit that included the PP, disc and flywheel. They will sell the clutch disc by itself, without a warranty.
Ford or Mopar discs with 1" diameter 23 spline and the appropriate diameter for the flywheel, PP and bell housing will work. Xschop, has been using one like that as well as others.
Which ever you decide to use it is recommended to take measurements to see what size shim you may need behind the slave cylinder. The spec kit came with a shim and everything measured out within tolerance.
Flywheel: GM 12571611 $275.00 Bought used 2k miles
Pressure Plate: GM 24233085 came with flywheel
Clutch disc: LuK no part number. Went to local clutch house and bought one for $45
Other clutch parts Im using:
Throwout bearing assy. : GM 89059282 $100.00
Flywheel Bolts: GM# 11569956 [ARP part #330-2802] 11 x 1.5 x 23.5mm 7mm head Free
Pilot bearing adapter: Value Tool Inc. Free
Clutch adapter/hose/fittings/speed bleeder: paid 107.45….90° 12mm to 3AN russells PN# R4054C and tickperformance.com
I am using a LS7 PP and flywheel, got it as a take off with surface rust for $75 shipped from LS1tech. then i got a really good deal on a RAM upgraded clutch disk that was the correct spline size/count from ebay brand new, [You must be registered and logged in to see this link.] it was 80 shipped roughly!!! And should take the power im hoping to make... Then im going to follow cfgioja and order the full boat lightweight setup... unless i hit the lottery and can get a multidisk setup...
Mark
Mark
Marky522- Posts : 175
Autozone CP-4018
Better construction than a stock LS1 disc (more rivets) and only $45
Fidanza Ls1 flywheel (fits truck motor crank pattern)...$225
Brand New Camaro Ls1 pressure plate....$50 ebay
xschop- Posts : 2710
adam7e wrote:Where'd you score the Fidanza for $225?![]()
there was one in midland tx few weeks ago for 125 on craiglist, brand new, let me find a link
modenas- Posts : 285
» what type of oil in your off road lawn tractor?
» Polaris changes RZR clutch, read if thinking of mods
» Clutch mods and battery relocation
» Ranger Clutch Kit install, RZR mostly the same
» Help Please, Rhino 700i, clutch/speed issue
» LSA Supercharged 86 Porsche 944
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» 924 Twin Turbo 5.3 C5 T56 swap!!
» Lighten clutch pedal feel?
