Traction Concepts LSD conversion for open differentials.
I was scanning the internet for LSD options for my open differential and came across a vendor called Traction Concepts who makes a conversion kit for $500. is this too good to be true? Does anyone have experience with this product? They don't give much information on how it works. Thanks, Gil
gwistrup- Posts : 113
Re: Traction Concepts LSD conversion for open differentials.
I've installed a hand full of those and they honestly don't work that well. Better than an open diff, but just barely.
Differentials
Sounds like you get what you pay for. What is the preferred option to change a conventional differential to a limited slip? I believe there are several manufacturers out there who make LSD units.
If it's a street car only, then the Wavetrac works really good. If it's a track car then you would need a clutch type LSD, like Guard or similar. Even a Porsche LSD can be set up to work really well on a track car.
Wavetrac is the least expensive at about $1500 compared to the others.
RE: LSD
I need to think about what to do with the transaxle. The car is street driven now but it will probably go to the track when I get all of the bugs sorted out. That will be the last item that gets upgraded. I have a 5R out of an '87 Turbo in the car now and it works fine except it does not have a LSD. I might be better off purchasing another transaxle with a LSD and selling my 5R. It would probably be cheaper than installing a new differential in the transaxle I have now.
You can usually find a turbo trans with LSD for about $2500. Much cheaper than a aftermarket LSD
Don't waste your time and money on the TC solution. It does not work and actually fails and causes a lot of collateral damage. I carry rebuilt factory LSD units in stock if interested.
Ironworker613 likes this post
Today at 3:06 pm by Rob44
