Early model 944 wilwood conversion - dimensions
Working to sketch up an adapter plate for the Wilwood Dynalite calipers. I have almost all the info i need to get the drawings finished up.
I was wondering if anyone had the measurements for an early model 944 front and rear spindle centerline to the stock caliper mounting holes radius. Should be able to get a rough number, but if anyone has actually cmm'd the parts all the better. Using this info along with the wilwood specs for the necessary " "A" Bolt Circle Radius" dimension in the image above to create the adapters.
Would be happy to share the cad drawings once finished with anyone that is interested. Should be pretty simple adapters to make up in the garage.
rjarvis- Posts : 61
Re: Early model 944 wilwood conversion - dimensions
This is a link to a very inexpensive set of adapters
https://www.wagenswest.com/product/944-front-disk-brake-wilwood-adapter-bracket-pair
» Turbo Transaxle wanted
