FS ABS Powerbrake system pressure pumps
I have two brand new ABS Powerbrake pumps available. these provide brake system pressure without a brake booster or any connection to the engine or vacuum. Used the std one on my 968 LS1 that has been sold so I no longer need them. Had then as spares. See ABSpowerbrake.com for master cylinder and other accessories to run the complete system.
The standard one sell new for $600.00 sell for $300.00 net paypal or shipping. The heavy duty one sells for $800 and will sell for $400.00 net. Both are available for immediate shipping.
Jpr
Jpr
jpr- Posts : 12
Re: FS ABS Powerbrake system pressure pumps
So which master did you run with this power unit?
kevin924kevin- Posts : 927
I used the 10-59 firewall mount. I ran it with the smaller pump, but bought the heavier duty pump in case that I tracked the car.
Jpr
Jpr
jpr- Posts : 12
Hi, Curious where you mounted the pump on your 968? I'm considering 10-59 or 66 86 944T w/ LT1 swap.
Rond948- Posts : 68
» ABS pumps available NIB
» sbc 350 carbed motor what to do for fuel pumps ??
» Help with pressure plate (SPEC pressure plate doesnt fit!!)
Today at 6:44 pm by Raindoc
» Turbo Transaxle wanted
Today at 4:26 pm by Raindoc
Yesterday at 3:06 pm by Rob44
