Oil pan fittings for remote filter - install dry?
On the TPC pan that has the remote filter mount, should I use any thread sealant on the tapered fittings that go into the pan or install dry? What's been the best approach to avoid leaks?
chrenan- Posts : 203
Re: Oil pan fittings for remote filter - install dry?
If they are NPT threads then use PTFE tape or the like, never install NPT dry.
Those are AN fittings on the oil lines. Yes, connect them dry and don't over-torque.
Coming out of the pan is AN, but what threads into the adapter on the pan is a tapered thread:
NPT, tapered, MUST have a lubricant/sealant applied before installation. It is especially important when the two materials are the same, Aluminum is more prone to galling.
Also, I would suggest that you consider using steel/stainless fittings, they will resist fatigue better than the Aluminum ones and the AN/JIC interface is more durable in the long-term.
That helps, thanks. I'll use some Loctite aviation thread sealant and look for steel fittings when I run the oil lines to the filter/cooler.
» FS: LSx swap parts; remote oil filter mount with fittings, engine harness boot
» Remote oil filter
» Remote Oil Filter Lines for use with the LS1
» Remote oil filter
