Pcm tach output
Pcm tach output
Hi I'm running into a little problem . I'm trying to wire my tachometer to my pcm but it doesn't have to wire on the pcm my model is a 2005 savanna 2500 model with a 4.8 engine drive by cable . The pcm on the green connector doesn't have a white wire in the slot 10 .my question is has anyone seen this before? Do I add a wire and get it tuned in or do I need to do something else to work with the original tachometer ? I also don't get A signal on my data wire for the obd2 port but that is not my priorities now. My car is a 1986 944 NA late dash
matt889- Posts : 214
Re: Pcm tach output
not all harnesses will have wire for the tach output, as most send the tach over the data bus. you can simply add the wire to the harness and have the tuner turn the tach output on in the ecm when the security stuff is being removed.
Re: Pcm tach output
And for the serial bus not sending any data to my scanner? My pcm was already flashed now I can't get any data when I plug my scanner on the green wire
Re: Pcm tach output
How did you wire up the obd plug?
Re: Pcm tach output
I used the serial class 2 data wire (green), an obd2 power and the ground . My scanner turn on from my power ND ground just no communication
Re: Pcm tach output
i believe you need the high speed data bus wiring at the obd2 plug. id have to dig around some more to know for sure.
edit:
did some more looking, apparently that pcm only uses serial data to communicate with the scan tool. my guess would be that your pcm isnt powering up, check your constant power source, switched power and grounds.
edit:
Re: Pcm tach output
On my pin out there is only one data line weird wire is green I will have to confirm the pin but it's in the 58 dark green
Re: Pcm tach output
i got the obd working and i added a tach wire and no rpm is showing -.- is a resistor needed for a late dash ? i have pluged my tach wire to the greeen wire of the 8 pin connector under passenger side
Re: Pcm tach output
the pcm needs the tach output turned on in the tune. the factory gauge cluster (if it had a tach) gets its tach signal through the data bus.
Re: Pcm tach output
matt889 wrote:i got the obd working and i added a tach wire and no rpm is showing -.- is a resistor needed for a late dash ? i have pluged my tach wire to the greeen wire of the 8 pin connector under passenger side
Depending on what year your ECU is, you may have to install a pull up resistor. I've hooked up the tach wire direct on 98-01 ECU's, but on 03-up I had to install a pull up resistor to make the tach work.
Re: Pcm tach output
got the tach working thanks now i need a tune ...
Re: Pcm tach output
what did you do to get it to work? it could help others in the future
Yesterday at 3:06 pm by Rob44
