C5 Calipers
C5 Calipers
An adapter bracket might be a *very* simple plate to have machined. I found the below measurements on the net. The C5 rotor disc is ~27mm larger in diameter on front, 16mm on rear. I couldn't find a pad-height/width measurement.
c5 rotors
front: 1.19" (30.2mm) thick 12.8 (325mm) in diameter
rear: .94" (23mm) thick 12" (304mm) diameter
87 porsche 944 na
front: 22mm thick 298mm (11.73") diameter
rear: 18.6mm thick 288mm (11.338")diameter
c5 rotors
87 porsche 944 na
endrnet- Posts : 129
