F-Body 5.7 LS1 Wiring Harness and PCM work with 4.8??
I have a wiring harness that was made for a LS1 5.7 and PCM. The PCM is from an F-Body. Will this combo work for someone running the LS1 4.8 truck engine?
Re: F-Body 5.7 LS1 Wiring Harness and PCM work with 4.8??
Here's a good place to start:
That should also have info on your PCM so you can figure out what (if anything) may need to be re-pinned.
The site has lots of detailed information, but it could be a bit better organized. You will probably need to dig through a bunch of different pages to figure out all the fine details related to what you are looking to do. It also has links buried in the text to other resources as well.
erioshi- Posts : 227
what year 4.8l? there were 2 different crank and cam trigger wheel combos through the years. the ls1 and early (gen 3) truck engines use a 24x crank trigger wheel, late model gen 4 engines used 58x.
as long as you use an early 4.8l engine (i think around 06 is when they changed) you should be ok.
The engine is a 2002 lr4 4.8 ls truck engine.
yamamtx- Posts : 97
