Parting out v8 swapped '85.5... lots of performance stuff
+4
brinskan
zeusrotty
Jasonscottw
admiralkhole
8 posters
Parting out my 85.5 LT1 swapped beast...
All swap parts (bellhousing, aluminum flywheel, spec stg2+ clutch and pressure plate, mounts, uprights, headers, y pipe, modified oil pan), lt1 engine with less than 500 miles on rebuild, painless wiring harness, reman ecu.....$3,000. Pretty much everything you need to drop engine in and run.
Swap parts only- $1,500
924 Carrera GT front bumper WITH euro driving lights - $250 (local pickup only)
Bridge spoiler with trim piece (not 968 wing) - $120
951 diffuser - $80 ( not perfect, bolts came out and someone put some in for me)
Script rear seats - $75
968 harness bar - $125 (unknown make, bolts to b and c pillar)
944 S2 font calipers with ceramic pads - $175
Boxster calipers with ceramic pads - $275
Rear bilstein diy coilovers - $400 (less than 100 miles on them)
M030 caliper adapters to work with NA spindles - $150
'87 Carrera rotors, cross drilled and slotted almost brand new - $65
Front coilover setup, bilstein HD inserts, coilover sleeves, racers edge top hats 450 lb springs - $350 (less than 100 miles on them)
S2 brake master cylinder - $30
Stainless front brake lines - $30
Clutch master reinforcement bracket - $75
951 radiator - $85
25.5mm front sway - $60
20mm rear sway - $150
015 manual sport rack with intermediate shaft - $250
BBS LM replicas 18x8.5 et52 - $475
Early caster blocks with red welt bushings - $35
Inquire about any other parts I might have.
Located in central Texas
951 radiator - $85
admiralkhole- Posts : 62
Re: Parting out v8 swapped '85.5... lots of performance stuff
Also 9U LSD 951 trans with only944 shift linkage - $1200
Interested in rims. Did they require spacers?
I've got an 87 with stock rotor/calipers.
Jasonscottw- Posts : 125
The BBS LM replicas are for sale, the 997 ones are not. They should for a late offset car with no spacers but I'm not quite sure... The offset is et52.
How much for the clutch and pp?
zeusrotty- Posts : 444
Sorry I forgot to post... I have several parties very interested in buying the car as a whole. I will post as soon as I wish out the details. Optispark just went bad... 5k takes all.
Any photos of how the harness bar looks installed?
brinskan- Posts : 15
Is the car running? Interested in everything.
Motoboy- Posts : 4
Motoboy wrote:Is the car running? Interested in everything.
Optispark just took a dump...so no. 5k takes it as is, everything.
Sorry about the delay everyone, I've been negotiating with several people on buying the car as a whole... I gave them a deadline of the end of next weekend or I will be parting the car. I'm in the process of moving and dealing with family/child stuff so things are going a little slow but I will get on it as soon as I can. Sorry if I hadn't gotten back to you
Car has been sold.
any swap parts left ?
matt889- Posts : 214
I ' m interested for swap part set (bellhousing,convert plate,cluth,presure plate,flywheel ,custom oil pan ) for 1500$.Send me to 07105 NJ? PM pls.
Pavka944- Posts : 17
admiralkhole wrote:Car has been sold.
Read...
