Lq4 build 944 NA
Lq4 build 944 NA
i starting taking the old 944 aparts its a 1986 late style dash ive had the car for more that 5 years stock and now im looking for some more punch out of it Smile This is a Canadian build !
heres my finds :
Lq4 6L engine out of a junk yard find Express van Unknown Millage So i opened it and refreshed it
~ Block is cleaned and honed by the machine shop
~New cam bearings
~Mesure and inspected the mains and rod : Perfect conditions so didnt change them
~Installed new OEM ring kit
~Full gasket set by rock auto
sourced ls1 camaro parts
~Crank pulley @ rock auto
~Alternator with bracket @scrap yard
~PS pump with brackets @ scrap yard
~LS1 camaro water pump @ rock auto
~Tensioner @ new
~Belt with out AC
For the dash gauges to work
~ÜRO PARTS 92860620301 Oil Pressure Sender
~Fitting is a Mod'ed O2 bung with a Transmission cooler fitting welded together and fits perfect ( all post pictures later )
~ Coolant sensor VDO Gauges A2C59517248S ( didnt received yet )
~ VSS kit from TPC
~ Im gonna use the Porsche fuel pump for now
Adaptors and custom parts
~ TPC Kit
Exhaust
~Modding a set of hooker 2312's ( In progress )
Im still waiting for some TPC parts * motor mounts * were out of stock .
I will post pics later i cant seem to upload them from my phone
Here are some Misc pictures i took of progress
matt-.-
heres my finds :
~New cam bearings
~Tensioner @ new
~Belt with out AC
~ VSS kit from TPC
~ TPC Kit
Exhaust
matt-.-
matt889- Posts : 214
Re: Lq4 build 944 NA
updates
i installed my engine for TT engagement mesuring, Seems to me that the truck engine already have a longer crank and i didnt need to ajuste the Shaft engagement for this application , Here is some pictures of my progress slow but working on it
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
