TPC Oil Pan Gasket?
+3
gdopnt
brinskan
7 posters
TPC Oil Pan Gasket?
Hey guys, I'm finally getting around to installing the Ls1 in my 951. I have the LS on the engine stand now and wanted to get everything bolted on. Question is what is everyone doing for a gasket on the TPC oil pan? The stock unit sits recessed into the pan, it seems the TPC unit would use a more traditional flat pan gasket or maybe just RTV?
And yes, I used the search function... It get no items found when I search oil pan... seems weird.
brinskan- Posts : 15
Re: TPC Oil Pan Gasket?
Wait... I think I just realized that metal part is part of the gasket and not the stock oil pan. So I guess the question now is can I reuse the GM unit?
How is it you became trained in the way of the search function.
gdopnt- Posts : 127
brinskan wrote:Hey guys, I'm finally getting around to installing the Ls1 in my 951. I have the LS on the engine stand now and wanted to get everything bolted on. Question is what is everyone doing for a gasket on the TPC oil pan? The stock unit sits recessed into the pan, it seems the TPC unit would use a more traditional flat pan gasket or maybe just RTV?
Click "Search"
Click "Advanced Search"
Type keywords into search box and click "Search Google" immediately to the right of the search box
oil pan
944-LT1 wrote:
Click "Search"
The above method is used for this forum? I have never seen any "Advanced Search" on this forum. What are we missing?
Tehone- Posts : 84
Tehone wrote:944-LT1 wrote:
Click "Search"
When you click " search", advanced search is right below the white dashed line on the box that pops up.
spence wrote:Tehone wrote:944-LT1 wrote:
Click "Search"
Thanks Spence but no go. It doesn't work for me but hope it works for others.
Tehone- Posts : 84
Are you using the 'Search' located between FAQ and Memberlist on the row just ABOVE the right side search field box?
944convert- Posts : 253
NOPE!!!
I have looked at that menu bar and never saw the "SEARCH" between the FAQ and MEMBERLIST.
I only used the SEARCH on the right side of this area below the LOG IN/LOG OUT button because it just seems to pop out as the obvious place to go.
I apologize for taking this thread and turning into an explanation point on how to find the SEARCH button for the ADVANCED SEARCH option.
Maybe Admin or the Moderator can cut this info out and place in an area that can be found for others if they have/had the same blindness as I did.
THANKS EVERYONE!!!
THANKS EVERYONE!!!
Tehone- Posts : 84
THANKS EVERYONE!!!
