Check engine warning light
I had a code because a coil bank had a loose connection. How do I reset the Check Engine Warning Light?
Re: Check engine warning light
Get an OBDII scanner, that can reset it. A lot of auto parts stores will let you borrow one. They are cheap enough you should have one in your tool box.
Codes
Have a scanner, should have reviewed instruction manual before posting here.
Codes removed OK and light now out. Many thanks.
