What LS Exhaust Manifolds / Headers
+6
ynbad
Tehone
epsylon9mm
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: What LS Exhaust Manifolds / Headers
What accessory bracket are you guys running?
Does the GM PS pump have to be modded for the 928 PS rack?
Also to confirm, does the Sanderson LS134's have the O2 sensors built in?
And does anyone have a picture/dimension of the rear driver's side head to firewall clearance?
I would like to set the drivetrain back another 1.0" to get more CV clearance when I mount the 6-speed.
Bracket and pump
I used a aluminum bracket from a company called Dirty Dingo
The pump works fine. Steering is a little stiff but better than too loose.
ynbad- Posts : 9
That 928 looks so cool like that.
As far as the PS goes I thought someone said that there is a GM power steering unit that the Porsche 928 lines would bolt right up to. Anyone know which PS unit that is. Are you thinking about retaining the original 928 PS reservoir?
I plan on using the F body accessory brackets. Did anyone have to have special hoses manufactured to retain the original Behr radiator?
Aaron
Aaron
Amille28- Posts : 5
P/s pump and lines
I used the 2004 silverado pump and brackets except for the alt and p/s pump bracket that I bought from dirty dingo so the alt would clear the hood. The lines for ac and ps I took the Porsche lines and the gm lines to a shop that make up pressure line and had them cut and splice. Worked nicely. This set up put the ac compressor right by the Porsche ac lines for easy plumbing. I'm up and driving now but haven't finished the details on the ac. Don't expect any problems.
ynbad- Posts : 9
I used 2002 FBody Headers on my 928 conversion. They cleared just fine.
hp18racer- Posts : 2
Were those the OE or after-market headers?hp18racer wrote:I used 2002 FBody Headers on my 928 conversion. They cleared just fine.
erioshi- Posts : 227
LS1 Fbody Headers (From a 2002 Camaro SS in my case) worked just fine.
Page 2 of 2 • 1, 2
» Exhaust manifolds?
» Looking for exhaust manifolds
» Experiences with the TPC manifolds vs. headers?
Page 2 of 2
Yesterday at 8:32 am by Rob44
Yesterday at 8:28 am by Rob44
