Experiences with the TPC manifolds vs. headers?
As my HP goals are pretty modest for the class I am racing in (2400lb/300RWHP), I was thinking of going with TPC's manifolds to save money over the headers. Anyone tried these out on a dyno?
Sterling Doc- Posts : 113
manifolds
I have Eric building me a set of stainless manifolds thjat will see the dyno.
kevin924kevin- Posts : 927
Re: Experiences with the TPC manifolds vs. headers?
We put a set on a friends car and made 402 rwhp.
02 ls1 w/ 243 heads, torquer v2 cam, 2-1/2 duals.
Runs like a scared rabbit!
Patb- Posts : 46
I'm using TPC's ceramic coated longtubes on a completely stock LS1 with 70k miles, and put down 317 rwhp on the dyno. Went to Cincy Speed for the tune.
jpkinerk- Posts : 174
I ended up getting a set of the TPC headers from a fellow list member. I'll see what it dynos. Depending on my weight I'll need around 300RWHP to max out the HP/weight for NASA ST3.T If I decide to run ST2, I'll need around 330-340. This all should be doable.
You may have to de tune depending on which class you run...
