Question about brakes
As you are all aware I bought DVC's 948 and I am getting it ready for the track. It currently has the stock brake setup and is using a electric power brake booster. I guess my question is, will I need a proportioning valve or a bias bar, or what? Or can I just leave it alone?
zeusrotty- Posts : 444
Re: Question about brakes
Not sure is the best answer. To my knowledge nobody has used the electric brake setup on the track. I can tell you I had to install an adjustable rear proportioning valve with my hydroboosted setup...
Before I had one in, hard braking on the track was very exciting. On the street I couldn't tell the need for one at all...
docwyte wrote:Not sure is the best answer. To my knowledge nobody has used the electric brake setup on the track. I can tell you I had to install an adjustable rear proportioning valve with my hydroboosted setup...
So you had to dial out the rear braking force? To be honest, the electronic booster is a pain. The Guy that built the car put the pump and electronics in the fender well in front of the driver. So one night I was driving the car after installing the wide body, and I had no power brakes. Yikes! The plug that the relay for the motor were loose and corroded, and weren't making a good connection. So I had to order a new 5 wire connector and a few more relays. I have rewired the relay Into the engine bay. That way if the relay goes again, I don't have to pull the wheel, and the fender liner to change a relay.
On the other hand pedal feel is strong and sure. But as far as reliability on a race track, hydro boost would be my pick. Unless someone knows something I don't.
You might want to contact 968ls1 he has built a couple cars with the electric booster.
Yes, I had too much rear brake bias. With the big reds up front now I had to send a little more brake bias to the rear.
Arthropraxis wrote:You might want to contact 968ls1 he has built a couple cars with the electric booster.
Do you know his real name?
zeusrotty wrote:Arthropraxis wrote:You might want to contact 968ls1 he has built a couple cars with the electric booster.
Never mind... The infamous Tom Egan
