Shifter stiffness
Shifter stiffness
I have a short shifter kit installed and the shifter lever is adjusted in accordance with the Porsche Workshop Manual. Problem is the whole thing is stiff in fore and aft movement.
Shifting from 1st to 2nd takes quite a tug. Any ideas, is this a negative function of short shifters?
(Gearbox is a Turbo LSD in my 88 NA 944.)
Maybe I'm spoiled by the silky smooth T5 gearbox in my MGB!
Re: Shifter stiffness
You loose leverage with the short shifters so your effort is increased.
Dawgz83948- Posts : 603
