I just bought DVC's 944... AND NOW I DROWNED IT IN A FLASH FLOOD... And now the rebuild starts!!!
+13
the951racer
vundba
odurandina
RobotMachines
laptop_geek
zeusrotty
17 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: I just bought DVC's 944... AND NOW I DROWNED IT IN A FLASH FLOOD... And now the rebuild starts!!!
Sounds like a plan! Thanks for the input!
zeusrotty- Posts : 444
Might want to put a couple of bottles of Heat in your gas tank or something that gets water out of your fuel system.
Is putting a little oil into the cylinder through the plug hole for the initial start a good idea?
Good plan...it wudden hurt at all…and I would as well (if I was doing this).
Just expect some smoke when you fire it up…and don’t worry about it.
944convert- Posts : 253
One of my friends hydrolocked her motor. After changing the oil, draining water out of the airbox and adding several bottles of Heat in to the gas tank we pulled the plugs and turned the motor over. It was an I6 and shot water out of the plug holes all over the cars next to it, looked like a sprinkler. It started up after putting the plugs back in but had a bent rod. I hope you are more lucky.
Many of the (top end) 250,000 cars 'written off' in the Sandy flood have a 'DO NOT START' message on the windshield because even the attempt (of starting) a hydro-locked engines can bend a rod. I have seen more than one Panamera being towed out of the "Sandy" hell hole with the 'do not start' message. The salvage crews know what they are doing
Well if the motor is toast I have to get a new one anyway. So it doesn't really hurt to try. Also the cars your looking at probably still have water in them. Mine is bone dry.
Arthropraxis wrote:One of my friends hydrolocked her motor. After changing the oil, draining water out of the airbox and adding several bottles of Heat in to the gas tank we pulled the plugs and turned the motor over. It started up after putting the plugs back in but had a bent rod.
If it was running when the water got sucked in...you are already too late...you will be trying to compress water and will bend a rod.
If the car was sitting & not running when if was flooded...then the piston rods are safe from being bent. As long as you 'do not start' it…it can be easily disassembled, carefully cleaned and rebuilt.
The motor did suck in water a few months ago while it was running and then i let it dry out for 5 months. I figured I would try it out and see if a rod is bent and it is. Tried it out last night and its knock, knock, knockin on heavens door. Forged LS2 pushed out to a 402 is the plan.
That just sucks! Why not go for broke and build a 427!
Well, I'm kinda redoing the entire car at this point. Complete with every Elephant Racing and Racers Edge bushing, Moton Club Sports, Bruce's torsion carrier, GT3 calipers, etc. So after I rebuild the suspension and get that all fixed up and perfect, that's when I will decide on exactly how I'm going to do the motor. And how much money I can spend on it. But my feeling on its that this thing was a monster with 450 HP. How much more do I really need? I couldn't get the 335's to stick as it was... Lol
Just so everyone knows, I'm doing Mortgage loans in Illinois, Colorado, and California now in order to fund this bad boy! LOL
zeusrotty wrote:But my feeling on its that this thing was a monster with 450 HP. How much more do I really need? I couldn't get the 335's to stick as it was... Lol
One of the smartest things I've read here.
Well thank you sir.
So you guys finding it easier to pull these motors from the top or bottom. Anything I should know?
Did I screw this up? Or does that just pop back in there? The good news is that the motor is on the ground without incident.
[url=[You must be registered and logged in to see this image.]][You must be registered and logged in to see this image.][/url]
I would get a new one for peace of mind. If you do get a real GM slave, the first one I had was a cheap off brand unit. It was leaking with in 200 miles.
zeusrotty wrote:Did I screw this up? Or does that just pop back in there? The good news is that the motor is on the ground without incident.
You could try to fashion it back together but I'd get a genuine GM slave. It would suck to have to pull the engine, just after getting it going, due to the slave going wrong.
I think I have a spare replacement bearing that I could send you,I'll see if I can find it.
Sounds good... let me know. I actually haven't looked at it since I dropped the motor, so I may pull it and get it checked out. It only has about a thousand miles on it because I just had it replaced...
I have a brand new bearing (just the bearing and plastic piece) It's yours if you need it. Just pay a small shipping and handling fee! "sounds like a TV ad"
Admin wrote:I have a brand new bearing (just the bearing and plastic piece) It's yours if you need it. Just pay a small shipping and handling fee! "sounds like a TV ad"
let me know where and how much you want the paypal to be.
Thanks, got it,
It will be shipped out today.
Latest pics
here are the latest pics!!
[You must be registered and logged in to see this image.]" />[url=[You must be registered and logged in to see this image.]][/url]
[You must be registered and logged in to see this image.]" />[You must be registered and logged in to see this image.]" />[url=[You must be registered and logged in to see this image.]][/url]
» Starts immediately stalls
» HELP!!! motor starts and runs smoothly for 3 seconds then abruptly dies
» Marc948GTR build
» Marc948GTR build
Page 3 of 4
Today at 3:06 pm by Rob44
