HELP!!! motor starts and runs smoothly for 3 seconds then abruptly dies
Got the car back from being painted and the engine bay was sprayed clean. Since then it's been having trouble running. I was able to drive the car home but since I parked it it will not run more than 3 seconds. It turns on right away and idles smooth. Does anyone know what is going on?
c0dyzimm3rm4n- Posts : 5
Re: HELP!!! motor starts and runs smoothly for 3 seconds then abruptly dies
OBD reader is your friend for this. No way of knowing for sure short of reading codes......IMO.
Gordo.
Gordo.
murrayg- Posts : 105
Did you ever find out what was wrong?
To me, this sounds like the vats is killing the ignition, though I can't venture a guess as to what would have caused it to start doing so after having the engine bay detailed.
Hey_Allen- Posts : 37
Today at 12:47 am by sharkey
