Lighten clutch pedal feel?
+11
v2rocket
marc a
a951
15 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Lighten clutch pedal feel?
I didn't touch the fuse box, just laid on my back and intalled it. Mine was in pieces so it took some time to figure out how it all went together.
I didn't measure, I just adjusted it to where I liked it, and then backed it off some as suggested by Admin as I described in this thread. No problems so far.
acorad- Posts : 697
I found this that has an A dimension from the body to rod center. It may help to set it up properly.[You must be registered and logged in to see this image.]
Got it in just now. Acorad, I'm very impressed that you were able to get it installed from underneath the car! There was NO way I was going to be able to pull that off. Once I managed to stuff myself underneath there (no small feat) I didn't have enough elbow room to work properly. Just couldn't get my hands up there.
Moving the fuse box was easy (although I should go out and make sure my car still starts and nothing was dislodged!) and after I removed the small plastic trim piece the clutch arm was staring me in the face.
It was a bitch wrestling that spring in there, the trick of using a vice and zip ties was instrumental. I found I had to have one on either side of the spring to hold it relatively straight, then I was able to finally lever it into place.
I adjusted it to factory specs and tried it out. Results are good! For the lack of a better description, the clutch feels normal now. Definitely easier to depress it, smooth going up and down. Should be a whole lot nicer to drive now.
Cross another thing off the "Off season to do" list. Next up is the LS6 PCV valley cover.
Doc, yeah, I'm pretty happy with it also. Such little things make a huge difference!
acorad- Posts : 697
I would like to have more discussion on this thread please.
I have an LS3 with a stage 2 clutch and hard to push. I had the original Porsche clutch MC and now a Tilton. Both still seem twice as hard to push than the stock 944 clutch. So I am wanting to know if
I possibly need to replace my clutch assist spring or did someone find a suitable stronger clutch assist spring for these stage 2 clutch pressure plates. I would love to soften this all up please.
Any wisdom on this would be great. I am looking for a possible stronger spring if someone has already done it. Curious if just a new Porsche spring would do it. Mine is compressed as much as I can and it does not help.
Another thought is the master cylinder size. I'm using a 1" Willwood Compact Remote as I couldn't get good clutch release with the 13/16" that most of y'all use. But the pedal effort sure is high. What's in your car?
Clutch Pedal Assist Spring
I have the Wilwood 13/16" Clutch Master which works great, but a real workout. If I could just get the right spring to make it feel as it was stated earlier "like a honda" that would be great. I am just looking for
1. What is the right spring to use
2. Where do I get it.
3. Will it fit where the Porsche assist spring was removed?
**EDIT**
I purchased the late model BLUE COLORED clutch assist spring new and after install I will know if I just needed to replace this spring with a new a slightly stronger one or if I need to go further and purchase and even stronger spring with the same dimensions. I will post back on this after install in the next week or so. The BLUE spring is supposed to be for the late models and a little stronger with the same fit. It should at least be stronger than the one I have and new which may fix the problem. ****
**EDIT**
Last edited by Porsche951toLS3 on Sun Feb 10, 2019 6:07 pm; edited 3 times in total (Reason for editing : Added info)
I just finished installing the new blue spring which was made for the later Porsche 944 cars.
The verdict is in..............YES. This helped me alot. It feels soooooo much better. My old spring was not broken, but it was 30 years old and probably needed to be replaced. Having a new spring and the stronger blue one really seemed to help. I cannot get it to Honda Pedal easy, but definitely it is not going to wear out my leg anymore. I still need to drive it, but it was a definite improvement for a new one off ebay at 39.00.
I did notice that the blue one had less coils than my old one which probably had something to do with the strength of it. Other than that, everything was the same in size. If I ever venture for an even stronger spring just to mess with this more, I have my old one out to easily get all the dimensions.
***SOLVED**** Clutch Pedal Assist Spring
I finally found a stronger clutch assist spring for my heavier Stage 2 clutch.
I went from my original spring to the blue spring found on the later models.......a little better and easier to depress the pedal, but only a little better. I took the time to find the following that gave me what I was looking for..... a perfect match for me and maybe others.
Vender - McMaster-Carr [You must be registered and logged in to see this link.]
It should be Spring-Tempered Steel Compression Spring, 3" Long, 1.281" OD, 0.905" ID
It cost me about 7.50 and I did not learn the shipping until it shipped which was 7.50 to ship.
Total cost for me was about 15.00. At least it worked for me.
The new spring fits perfectly and is a much stronger spring. I had to compress it CAREFULLY with my bench vice and hold it compressed with zip ties to get it installed........strong little guy. I suggest you put 3 zip ties onto the spring prior to compression and then tighten the zip ties as you compress so you don't put an eye out After it was installed, I cut the zip ties to release the spring and then tightened the spring about the same as the old one. You have to adjust it by feel.
Hope this helps if you ever need to lighten your clutch pedal. Pictures below. The square metal spring
is the new one I just received from McMaster.
Last edited by Porsche951toLS3 on Sun Mar 10, 2019 1:32 am; edited 5 times in total (Reason for editing : remove picture)
Thank you for the detail - very helpful.!!
Worryless- Posts : 13
Page 3 of 3
Yesterday at 8:32 am by Rob44
