Yesterday at 10:33 pm by mryan318
» 5.3 conversion on 88 Turbo
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
clutch pedal sticking to floor
Post  dallas on Mon Nov 22, 2010 3:00 pm
Hi guys,
Took the car off the trailer 2 weeks ago. Its been there for about 6 mos. Rotor cuff surgery took me out of business. Nasty! Well the car was started often on the trailer but obviously thats about it. I'm now having trouble with the clutchpedal sticking to the floor. I bled it 3 times and it got better but still sticks after car warms up. I never removed the spring from the clutch pedal. Could this be the problem? Clutch grabs about 1/4 the way off the floor which seems normal. Its the sticking that is getting me. Anyone had this problem? I forgot how much fun these cars are to drive.
dallas
Re: clutch pedal sticking to floor
Post  Porch on Mon Nov 22, 2010 3:14 pm
You don't have to remove the spring, you can just adjust it. Loosen the nut up a little (pull the fuse box out on the later models, then remove the plastic cover) and you should be good to go!
Post  Bridar on Mon Nov 22, 2010 3:17 pm
What kind of clutch? Are you pressure bleeding? Did it work OK prior to the 6 month hybernation?
I am running an LS7 clutch with the spring and it works fine. The spring helps to reduce the amount of force you have to hold down when at a stop light. You could try backing the tension off the spring all the way (turn the adjustment nut all the way out as indicated in the prior post), but I don't think that is the problem. Perhaps the pressure plate got a little rusty and it will free up with use.
Bridar
Post  dallas on Mon Nov 22, 2010 3:23 pm
Thanks I'll try it tomorrow. I've got to change the seat also anyway. It seems to get sticky after I drive about 10 miles or so. Works well cold. Seems to be sticky at just the absolute bottom. 1inch off floor its fine. Maybe it is the spring. The clutch is a LuK replacement with RH disc. Was very grabby before layup. Must have self adjusted some.
dallas
Post  948 on Mon Nov 22, 2010 9:19 pm
IMO, 1/4 off the floor is way too low. If your clutch master cylinder has not been changed, start there and report back. Also check your slave adjustment....
Can you pressure bleed from the slave up and out?
Post  944-LT1 on Mon Nov 22, 2010 9:34 pm
Just a guess, but it seems to me that the master is old and the rear of the bore (nearest the outlet) may be corroded. Recently you may have adjusted the clutch pushrod? This would force the piston to travel into this corroded area. When you depress the clutch pedal, the piston/seal may be sticking in this area.
You should also check the bushing of the clutch pedal pivot. This could be totally degraded.
Post  dallas on Wed Nov 24, 2010 3:46 pm
I'm pretty sure I changed the clutch master about 4 yrs ago. I went with the superblue fluid from Ian at 944online. I still haven't touched it yet. Physical therapy keeps me busy, as well as trying to get my wireless internet up and running. As for the corrosion in the master I know about that stuff. Do a brake job and bleed the brakes and end up doing the master a week later. Thanks for the replyies. I'll post the results when I find out.
dallas
Post  dallas on Sun Dec 05, 2010 8:13 am
Well it was the pedal assist spring. I backed off on the tension about 3-4 turns and the padal returns nice now. No inadvertent holeshots anymore. Thanks guys. TT rebuild next.
dallas
Post  944-LT1 on Sun Dec 05, 2010 3:15 pm
Excellent! Very Happy
Post  cfgioja on Sun Dec 05, 2010 3:29 pm
Just curious on the Clutch pedal assist. Why do you choose to keep it in? If its a hydraulic system it should return, what does leaving it in do?
Post  dallas on Sun Dec 05, 2010 5:06 pm
If I have trouble with it again I'll probably chuck it. But right now with my shoulder it took all I had to get under there. Never checked to see what a total hydraulic would feel like. But I'm sure my size 12's could handle it. God these cars are rockets.Reminds of the original z28's with the 302's. Very Happy
dallas
Post  cfgioja on Sun Dec 05, 2010 5:09 pm
I use mine without thats why I am asking? It doesnt seem to give me any trouble. I didnt know what having it in did for the clutch feel.
Post  944-LT1 on Sun Dec 05, 2010 5:34 pm
It's like a booster. I kept mine in as well.
Post  Admin on Sun Dec 05, 2010 9:16 pm
For anyone that wants to remove the assist spring, on 85.5 and above, just pull up the fuse box and remove the plastic wiring guard and you can get to the spring without shoulder pain....
Post  dallas on Sun Dec 12, 2010 3:54 pm
Good idea! Hope I got enough slack in the wiring. Think I had it up that far once before for wiring, but never moved the guard. My friend has a 944t he's stripping now so I can check it out.
dallas
Post  matty89 on Sun Jul 09, 2017 2:49 pm
how does the pedal spring make ur pedal 1/4 inch from the floor to normal ???
matty89
Post  sharkey on Sun Jul 09, 2017 2:58 pm
if you read it again he dais "the clutch grabs 1/4 off the floor which seems normal", id guess he means 1/4 of the way up, not 1/4" (that would be very abnormal).
the problem with the spring is that with a light or weak pressure plate the force of the spring on the pedal can be greater than the pressure plate, making the pedal not return.
