Today at 8:58 am by JSP
» Tpc LS adapter plate
» Headers, headers, HEADERS!
Lighten clutch pedal feel?
Page 2 of 3 Previous  1, 2, 3  Next
Re: Lighten clutch pedal feel?
Post  Arthropraxis on Sun Oct 09, 2011 7:39 pm
I adjusted mine until the pedal had a smooth even feel to it. If there is too much pre load on the pedal it will feel like there is a break point where the pedal initially has resistance, hits the break point and then there is no resistance. I did measure it after I found the diagram posted above and it was about 55mm.
Post  v2rocket on Sun Oct 09, 2011 8:06 pm
if you go lighter than stock then youre a pussy who deserves a honda featherweight clutch
damn japanese need some leg strength, the 944 clutch pedal is proper
v2rocket
Post  944-LT1 on Sun Oct 09, 2011 8:28 pm
v2rocket wrote:if you go lighter than stock then youre a pussy who deserves a honda featherweight clutch
Yes, the stock 944 clutch MC is quite soft with the stock 944 PP. However, increasing CMC bore size along with HD aftermarket PPs = "clutch foot" after a few miles of traffic.
Post  docwyte on Mon Oct 10, 2011 12:20 pm
Stock pedal feel would be great! With the Spec stage 2, it's FAR heavier than stock, that's why I want to get the return spring back in place and see how it feels...
Post  acorad on Mon Oct 10, 2011 12:35 pm
fliermike45 wrote:Here is the spring installation viewed from the top after moving the relay panel.
Excellent pic, thanks! My complete spring assembly is missing.
Post  87-944S on Mon Oct 10, 2011 4:58 pm
Hey Arthropraxis, I measured mine, and it is also about 55mm. My setup is a Wilwood clutch M/C, RH pressure plate and whatever throwout bearing RH put in the bellhousing. I experienced the same thing, had to adjust until it was smooth. Feels good to me!
Post  acorad on Thu Oct 13, 2011 2:39 pm
Items on the clutch pedal arm (from top of picture): Nylon bushing, shaft eye, washer, circlip. At the far end of the spring is a nylon cap with two ears that rides on indentations in the body.
Hi Mike, all, I notice on my just-purchased clutch pedal assist spring assembly that there is a hole through the shaft/push-rod on the nylon cap end of the rod. Is something supposed to to through that hole, maybe to hold the spring assembly in place? Or is the spring assembly merely held in place on the rod by the force of the compression of the spring itself?
Post  acorad on Thu Oct 13, 2011 3:54 pm
Well the more I look at if the more it doesn't seem likely that there's a pin or anything that goes through that hole.
Also, as the ends of the spring are not attatched to fixed points they won't ever be under tension, so the spring is only to assist when you step on the pedal, it can't help the pedal return from the floor.
Post  acorad on Thu Oct 13, 2011 4:54 pm
Well, it's on. Huge difference. Maybe I won't be swapping out the clutch for a lighter model after all...
Post  87-944S on Thu Oct 13, 2011 6:22 pm
Nothing goes in that hole, I think it is there to put something in to hold the spring in place for servicing the clutch pedal. Sounds like this worked out for you!
Clutch spring
Post  fliermike45 on Thu Oct 13, 2011 6:42 pm
If you look at the excerpt from the Porsche manual on page 2 of this thread and read the line at the bottom, it explains the use of that hole.
Post  87-944S on Thu Oct 13, 2011 6:51 pm
I posted that excerpt and didn't even see that! I need to RTFM! Laughing
Post  acorad on Thu Oct 13, 2011 8:28 pm
fliermike45 wrote:If you look at the excerpt from the Porsche manual on page 2 of this thread and read the line at the bottom, it explains the use of that hole.
Well, there ya go! Instead of using tie wraps to keep the spring compressed when I mounted the assembly, I could have just pushed a cotter pin through hole. Sure would have been easier!
And...just realized that I had backed off the adjusting nut when mounting the assembly and forgot to tighten that nut back up. Doing so will reduce pedal effort even more...
Post  Admin on Thu Oct 13, 2011 8:45 pm
Now that you have that back together, pay close attention over the next few days to how the clutch acts and feels going through the gears. Listen /feel for gear noise and engagement. I remove these on the cars that I convert because I have had the spring push the pedal down just enough that the master bleeds of just a little and I do not full disengagement. On my personal car, when it was running, the pedal would be a 1/4 to 1/2" down before I even started driving. I removed the spring and it never did it again. I don't know why it did that and really cannot explain it, but it happened and the fix was spring removal.
Spring
Post  fliermike45 on Fri Oct 14, 2011 6:02 am
Acorad, for some reason I could not compress the spring far enough using the hole.
That's why I used tie wraps.
Post  docwyte on Fri Oct 14, 2011 5:12 pm
That's good news! Exactly what I want. I definitely don't have a problem with pedal return. Eric, have you finished moving yet? I'd love to get the spring setup now that it sounds like it'll do what I want!
Post  Admin on Fri Oct 14, 2011 8:43 pm
Remember , it's not a return assist, It helps on the down force....... I will be completely moved by Monday.
Post  docwyte on Fri Oct 14, 2011 8:59 pm
Yep, that's what I'm looking for. The clutch has more than enough pressure to pop up on it's own, it's just very heavy pushing it down...
Post  Admin on Fri Oct 14, 2011 9:20 pm
If you read my previous post closely , I have found the spring to slowly over time push the clutch down.
Post  87-944S on Fri Oct 14, 2011 9:31 pm
Hey Admin, do you have the return spring on the clutch pedal like the brake pedal? I'm wondering if this would keep the pedal from moving down like you have experienced. I haven't had mine running long enough to gain any experience on this topic yet, other than the clutch feels good, but stiffer than the 944s original one. Which to me is a good thing!
Post  docwyte on Fri Oct 14, 2011 9:51 pm
I did read that, but I'd like to have the spring installed anyways. I can always remove it if it becomes an issue, but the heavy clutch feel is more than I care to deal with...
Post  acorad on Fri Oct 14, 2011 10:20 pm
So I cranked up the compression on the assist spring today, just for kicks, and it's almost too easy now. fwiw, the engagement point of the clutch has moved much closer to the floor, no idea how that will play out over time.
Post  Admin on Sat Oct 15, 2011 8:23 am
Closer to the floor means it already disengaging the the clutch, Just as I wrote in my previous post. That means soon a slipping clutch and then slight gear grinding noise on most gears. Then near impossible to get it in reverse.
Post  acorad on Sat Oct 15, 2011 10:09 am
Admin wrote:Closer to the floor means it already disengaging the the clutch, Just as I wrote in my previous post. That means soon a slipping clutch and then slight gear grinding noise on most gears. Then near impossible to get it in reverse.
Thanks Admin, I'll back the adjusting nut off some and see how it does.
Post  docwyte on Fri Nov 18, 2011 10:37 am
Just got one of these in the mail yesterday. Hopefully get it in the car today and see what sort of difference it makes.
I take it I assemble it out of the car, use a pin to hold it all together, then just put it into place from above after moving the fusebox out of the way? Then pop the C clip in place, adjust it to 55mm and call it a day?
