High pressure hose from rack to power steering pump for LS swap
zeusrotty- Posts : 444
Re: High pressure hose from rack to power steering pump for LS swap
What pump did you use this with? The rack end fitting threads right into the rack? And the pump end, does it thread right into the pump with the proper fitting?
yes it does go directly to the pump. It fits on the 944 rack with the stock banjo bolt. All you need is a set of 12mm crush washers.
