C5 BH ?
C5 BH ?
Do you guys all use the corvette C5 BH ?
GudmundurGeir- Posts : 45
Re: C5 BH ?
Dude...different avatar please. Not that i don't enjoy the view, but i'm at work, and i can't be looking at a site with that as a picture.
Re: C5 BH ?
Most people are using the C5 bellhousing, there are however different options available. The C5 bellhousing is the easiest to use and requires less work.
+1 on the avatar. I'm here at school, this ain't rennlist.
laptop_geek- Posts : 230
Re: C5 BH ?
Sorry, avatar is gone
But the BH has to be from a manual transmission car right?
Re: C5 BH ?
I'm sorry your avatar is gone too.
2 piece manual BH if you want larger than 10.5" clutch
Re: C5 BH ?
Is it possible to use BH from a automatic car? Wich types of clutches are you guys using?
Re: C5 BH ?
Just get the 2-piece and 168T flywheel. You have to inspect your TT shaft insertion depth or you'll fry your TT shaft tip splines.
Re: C5 BH ?
Thank you, still need the BH and flywheel... and offcourse my oil pan from Greg Sloan
