Wanted! Stock LS1 airbox parts
+2
6 posters
Hey guys,
I'm looking for the stock plastic pipe from the airbox to the MAF, then the stock accordion hose from the MAF to the t-body.
LMK if you have em!
TIA!
LMK if you have em!
TIA!
Re: Wanted! Stock LS1 airbox parts
Smog Nazi's?
docwyte wrote:Hey guys,
LMK if you have em!
TIA!
Dawgz83948- Posts : 603
Nah, the accordion hose will let me move the intake up/down some and the plastic tube is super thin and will clear my head light bar better than a piece of pvc...
Thanks for the offer, but that's the one part I don't need!
I need everything from the airbox to the t-body with the exception of the MAF...
Have you thought of converting to the new LS3 MAF?
You can go with oval tubes then for better clearance.
How flexible are the mounting options for the LS3 MAF, e.g. distance from the throttle body, etc.? That sure opens up a lot more options for the intake tubing, it has me thinking. Especially since it is only 62 bucks from RockAuto:)
87-944S wrote:How flexible are the mounting options for the LS3 MAF, e.g. distance from the throttle body, etc.? That sure opens up a lot more options for the intake tubing, it has me thinking. Especially since it is only 62 bucks from RockAuto:)
The GM manual says the optimal distance is within 10-12 inches from the TB. But with a good tuning, you could probably get away with a bit more.
Do you have to change wiring harness plugs and tuning to run it? Besides its shape, what are the differences?
Have no idea. I do know people are doing it and tuners just replace the table with the LS3 table. You'd have to search it on ls1tech.
Heres a thread on it... Here
Heres the wiring adapter thats sells on ebay for ~$30.
