Speed sensor
Re: Speed sensor
Michael,
I'm not quite there yet with my build so I can' t help you right now. However, there are plenty of others on the forum that can.
I suggest you be a bit more specific as to what you're looking for. IE and entire wiring diagram or specific connections at the transaxle or ECM.
Raymond-P- Posts : 380
Re: Speed sensor
Michael Bivins wrote:Speed sensor wire routing
Michael,
I'm checking with you to see what progress you've made in this area.
I've finally caught up and my crossmember and transmission are both installed. Now I'm preparing to connect my new drive axles and the TPC VSS reluctor ring.
Note for those unfamiliar: VSS is an acronym for Vehicle Speed Sensor. In this application, the VSS uses a stationary, permanent magnetic sensor (reluctor) mounted to the transmission housing. The sensor is triggered by the teeth on a "reluctor ring" which is a toothed ring or gear that rotates with axle shaft. The reluctor sensor provides vehicle speed information to the ECM similar to how the crankshaft and camshaft sensors provide position and engine speed information. Collectively, this information is the basis for tuning the ignition timing for maximum performance and overall drivability.
< TPC VSS Sensor and Ring >
I have a 2-wire pigtail arriving soon to connect the reluctor sensor to my ECM, and I'm curious what guidance you may have received from the Forum experts???
Also...When you installed your reluctor ring, did you use the three (3) factory crescent washers (plates)? I'm thinking of NOT using these washers as I believe the reluctor ring will act as a substitute. Also, I won't be compromising the required embedment length of the flange bolts.
Thanks for any input you may have!!
Re: Speed sensor
Yes, replace the washers with the gear ring. I used a quarter as a spacer to set the space between with sensor and the gear ring.
