LS1 Intake with no hood latch
+4
8 posters
Here's the intake setup I made for the car that I am converting right now. It has a full 4" diameter inlet even though it is smashed down. It should flow great and has no restriction to the throttle body. I made a stand off piece for the throttle body to tilt it down just a bit for hood clearance and to make the tubes run a little straighter. I custom made a fiberglass tube to go from the air box to the throttle body. It is 4" at the throttle body and about equal to a 4 1/2" pipe ( even though it's smashed flat)at the air box.
I did have to remove a considerable amount of metal to get it in there, but we were installing hood pins anyway.
Re: LS1 Intake with no hood latch
Oooh, very nice! Whose car is that? Looks like a fancy suspension setup too...
yea definitely need something along those lines. I was thinking of a rectangular cone shape filter instead of just a plane cone and run it into that area too. That way it would have more breathing area for the filter.
Looks good though. Do you think there is any affect to the intake moving the TB like that?
There should be no problem moving the TB forward. If anything, look at all the TB spacers that JEgs and Summit sell that boast HP gains............
The car is a forum member, He'll chime in if he wants everyone to know whats under his hood. Yes there is a lot of nice suspension work and other stuff done to the car before I got a hold of it. Now it has a nice powerful V8
It looks to be in speed density mode, aka no maf.
Dawgz83948- Posts : 603
Ah, i didn't even catch the TB spacer. That's a good idea!
No MAF would be a downside for me, but if it were mostly a track car (or a big cam) it doesn't matter. I make too many elevation changes to run without a MAF though.
Yep, me too. Especially since I live at 5000-6000 ft above sea level and within an hour of driving can be up to 11,000 feet or almost down to sea level...
No MAF needed, this is a track car, but in at that we can make a street car run just fine, mine does......
Speed density tuning tends to freak out at altitude, ECU doesn't know what to do...
that's my car. I'm very excited at the progress to date and cannot wait to retrieve it! It is an 86 turbo with Motons and Racer's Edge bushings and goodies front and rear. This is a track-only car that has been limited by the fussiness of the turbo engine eating exhaust valves every 3-6 months.
eclou- Posts : 102
Yep, that's one of the reasons I did the swap too. Which tracks do you run?
Texas World Speedway, Eagle's Canyon, Motorsports Ranch (Cresson), Motorsports Ranch (Rosharon), Grand Sport Speedway, Harris Hill
eclou- Posts : 102
Nicely done on that intake.
Awesome care eclou.
Awesome care eclou.
DVC- Posts : 56
Gotta get yourself over to Colorado!
nice. looks good I am thinking to do this.
lvkid76- Posts : 12
