will a procharger fit with the LS conversion?
+3
7 posters
Ive seen pictures of vettes with this supercharger added and there just might be enough room on our cars too. Any comments?
89 944- Posts : 8
Re: will a procharger fit with the LS conversion?
Would you need a custom hood? The procharger goes on the front of the engine like an A/C compressor. You definitely need one for the Magnunsen unit that goes on the top of the engine.
Yeah. Theres the superchargers that mount facing the engine and then theres one that mounts with the accessories. The one that mounts facing the engine would probably hit the radiator and hood latch brace unless you get rid of the brace and move the radiator forward. The one that mounts with the accessories would probably hit the frame rail unless you mounted it pretty low = fancy bracketry.
The magnuson replaces the intake and requires a hood buldge.
I guess the question is....were you referring to the magnuson or the procharger?
Michael B.- Posts : 83
i say the pro charger will fit, yea it take some pass and fail fit test, but lights needs to be bucket, and go from there
modenas- Posts : 285
