944 LS Swap Noob
944 LS Swap Noob
Hey guys new to the forum. I've got a 1988 944 that I'm looking to swap a junkyard LS in. My brother and I have done plenty of swaps in older Chevy's but never anything like this. I'm sure we can figure out just about everything except for mating the 5 speed from the Porsche to the LS. Does anyone have any suggestions?
Manbear- Posts : 2
Re: 944 LS Swap Noob
this is fairly well documented. you need a corvette bellhousing and the adapter plate, as well as the swap clutch disc (you use an ls flywheel and pressure plate).
there is a ton of fabrication if you attempt this swap without the conversion kit.
You can get everything you need on this forum. All info required is here. Spend some time do a little reading.. click on Texas Performance on main page and shizam it's all there.. good luck on the build keep us posted.
kevin924kevin- Posts : 927
Yesterday at 3:06 pm by Rob44
