Exhaust Smell Leak Solved with Homemade Smoke Machine
Setup: 86 Porsche 944 Turbo / LS3 / 3" pipe to single pipe all the way back connected with Lap Band Exhaust Connectors.
Problem: Exhaust smell in cabin when stopped
Troubleshooting: Created a homemade smoke machine as found here:
I created this smoke machine and just put the outlet up the tailpipe with a bunch of rags. After less than a minute..............I found my problem or problem(s) which is what I am sharing.
As I looked under the car with a flashlight for easier smoke identification, I found every single one of my lap band 3" exhaust pipe connectors had small leaks where the bolts are used. Since I used about 6 of these to put my exhaust together to stay away from the having to pay to get my exhaust done, there were too many combined leaks which created a smell in the cabin.
SOLUTION: I am taking this to an exhaust shop to have all my connections TIG Welded.
*********** JUST SAVING OTHERS THE TROUBLE OF USING LAP BAND CONNECTORS *******
Last edited by Porsche951toLS3 on Sun May 26, 2019 7:10 pm; edited 2 times in total (Reason for editing : grammer)
