New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 21 of 31
Page 21 of 31 • 1 ... 12 ... 20, 21, 22 ... 26 ... 31
Re: New convert under way
I used the sum-380645 rad and mercury cougar v6 fans.
kevin924kevin wrote:Ok people, please chime in on a rad. I checked with Ron Davis and he wants 1600.00 and change with shroud and fans. This seems a little out there. I have to be able to keep 500 plus HP cool in the city driving and also for a bit of auto cross. There appears to be a bunch of rads made in the US that will fit our applications. Anyone with these units would be appreciated.
Check with Kent at TPC. He has billet radiators in stock
i used a champion radiator designed for a fiero. i built my own rad mounts and didnt use any of the stock stuff.
Thank you all for the replies.
kevin924kevin- Posts : 927
I've used TPC's radiator kits on different cars. They work very well. Has a shroud and 2 electric fans with the kit.
thank you sounds like a proven package.
Well got some work done this weekend. Motor down engine mounts off and ready for a little adjustment. Cross member out and modified as needed. I did a few changes to my rack mount and that is done and painted. Slow and steady.
Should have adjusted mounts back before the weekend, and my manifolds are in route and are to land Friday as well. Then its put it all back together and cross the old fingers.
Happy days. I picked up my altered motor mounts. This will now slide the entire drive line forward 5/8". this will help with my BMW Hydro boost unit. This will also set my axles in a better alignment to the trailing arms & the shifter location. One more thing done.
Please have a look. Will this work. How much do the motors move on the mounts..
Just another angle.
Just another angle.
Just a look from the bottom. So the way it sits right now no cross member spacer needed. I have clocked the unit right from 12 to 2 plus or minus. My bowl was 7 % I have set this at 10 kind of spit the difference from 12 % plus or minus. I am hoping to not have to drop the x member. The ls is now 5/ in forward. New shims in. The hole unit can go ahead a bit more just in the mounts on the block and a little loving were is bolts at the x member.
Shim in the mount they need just a hint of fine toning then I will level the motor just out a hair. May just leave it. Forward hoe. Getting so close to be able to final weld everything in place.
kevin924kevin wrote:[You must be registered and logged in to see this image.]
The urethane bushings are very stiff. You will probably get some chassis flex, but it won't be the mounts.
I've had the valve cover this close before and not ever touch.
Perfect thank you.
Picked up the TPC manifolds today. They are cute units. The fit looks fantastic. Lots of room between them and the frame rails. I will post a few pics tonight. There not headers, but they will breathe better than the stock manifolds. Now need the rad and few odds and ends and can really start to think about firing this unit up. So look forward to that day.
Might have to love the main dump for the steering shaft.
Pics are not working.
I see the on e pic of the manifold.
I will get the pics sorted out. It looks like the plug wires at the front on both sides touch the manifolds. I will most likely have to put a small dent in the drivers side main tube for the steering shaft.. The plugs wires are the biggest concern.
kevin924kevin wrote:I will get the pics sorted out. It looks like the plug wires at the front on both sides touch the manifolds. I will most likely have to put a small dent in the drivers side main tube for the steering shaft.. The plugs wires are the biggest concern.
You need to let Kent know about this. He needs to make changes if they aren't right.
Yes, i sent Kent an email explaining the few issues.
Hopefully theses turned out.
Page 21 of 31
Thu May 02, 2024 10:35 am by sepheroth86
Wed May 01, 2024 9:32 am by Rob44
Tue Apr 30, 2024 9:28 am by JW1970
Mon Apr 29, 2024 11:36 pm by zenon
Mon Apr 29, 2024 11:24 pm by zenon
Sun Apr 28, 2024 10:38 am by SpeedRacer11
Sun Apr 28, 2024 1:00 am by Raymond-P
Sun Apr 28, 2024 12:09 am by Raymond-P
Fri Apr 26, 2024 4:30 pm by ThomasJoseph315
