LT1 Heater flow Diagram
Hi: Eons ago either Paul 948 or LT1 put up a flow diagram that showed using either a stock or 951 overflow tank.This water flow chart was really a great explanation for cooling hose routing, including H-valve. I have a stock overflow tank. The old site doesn't seem to have that document any longer. Anyone know where to find it or have a copy ?
Thanks.
Thanks.
944-v8- Posts : 59
Re: LT1 Heater flow Diagram
gt1scca- Posts : 795
Hi: This is the way it flows now---correct.If we need the H-valve then it goes where the "Y" is at the heater ???? So that the water flows directly back when the valve is closed and I guess when it it open the flow goes through the valve to heater and back into the valve and back to the pump. I assume the large port is in from the pump and out to the heater and the return is the small port from the heater and then to the small port on the pump. Is that correct ?
Thanks.
Thanks.
944-v8- Posts : 59
I didn't draw it (944-LT1), I only linked it for you...
Here's 2 other diagrams...
shbox - radiator hoses
shbox - heater hoses
» LS1 reverse cooling
» connecting heater hose to heater ports at firewall
» Rubbed through the coolant over flow hose at the track
Today at 6:44 pm by Raindoc
» Turbo Transaxle wanted
Today at 4:26 pm by Raindoc
Yesterday at 3:06 pm by Rob44
