944Hybrids
Welcome to our forum.
» Pacific Raceways near Seattle
Today at 7:26 am by Lemming
» HELP . . . Electrical gremlin
Today at 12:01 am by Rich L.
» Rich's LS powered 944 track car
Yesterday at 8:59 pm by Lemming
» First Time Swap 85 Porsche 944 to LS6
Yesterday at 7:03 pm by kjducati
» Oil and steering cooler options
Yesterday at 6:11 pm by docwyte
» selling conversion parts due to new baby
Yesterday at 4:29 pm by zeusrotty
» Strut brace?
Mon May 14, 2012 5:38 pm by fliermike45
Mon May 14, 2012 1:56 pm by epsylon9mm
» building a 1983 948 on a budget - pointers?
Mon May 14, 2012 7:19 am by Admin
» To " badge or not to badge "
Sun May 13, 2012 5:01 pm by 944-LT1
May 2012
78910111213
14151617181920
21222324252627
28293031
LT1 / LS1 Spark Plug Info
Post  gt1scca on Sat Jun 20, 2009 4:21 am
LT1 Spark Plug Info
**Note: Heat ranges are determined by NGK standards. Not all plug manufacturers follow the same guidelines.
***Note: List is intended for reference only. Please consult with head mfg. and ignition mfg. for proper gap.
****Note: NGK IX and Denso plugs are Iridium.
LT1
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .050
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Champion RS14YC6 (stock number 13); Denso IT-16 (stock number 5325)
Nitrous (one step colder)
Heat range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
LT1 w/ AFR heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations
Heat Range: 9
Gap: Consult ignition mfg.
Plug: NGK 5672A-9 (stock number 7405); Autolite AR3910; Champion C59YC (stock number 792); Denso IQ27 (stock number 5315); Denso IQ01-27 (stock number 5708)(diagonal platinum ground); Denso IQ02-27 (stock number 5711)(horizontal platinum ground)
Heat Range: 10
Plug: NGK 5672A-10 (stock number 7942); Autolite AR50; Denso IQ31 (stock number 5323)
Heat Range: 11
Plug: Denso IQ34 (stock number 5324)
LT1 w/ Trick Flow & Edelbrock Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations: approx under 9:1 compression
Heat Range: 4
Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303)
MFG Recommendations: approx 10.5:1 compression
Heat Range: 5
Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304)
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
MFG Recommendations: approx 12:1 compression
Heat Range: 9
Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
MFG Recommendations: approx 13:1 compression
Heat Range: 9 - 10
Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
MFG Recommendations: approx 14:1 compression
Heat Range: 10
Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
**NOTE: Use chart for static compression and adjust heat range for nitrous use accordingly.
LS1 Spark Plug Info
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
LS1 w/ Edelbrock and Dart Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Heat Range: 4
Heat Range: 5
Heat Range: 8
Heat Range: 9
Heat Range: 9 - 10
Heat Range: 10
