Front motor oil leak while your in there list
Newbie to sbc's 1997 LT1(Camaro)
Oil leak from wp/opti area looking for all suggested items to replace and best brand(s) and Sources for parts. Thermostat temp? 160? Serpentine belt size w/o AC. Optispark oem? Etc.
Any help appreciated.
PS whine issue stock gm pump.
Any truth to feed/return line orientation as cause?
Rond948- Posts : 68
Re: Front motor oil leak while your in there list
Not really much to do "while you're in there" since you aren't really into much with replacing the water pump seal. I would just replace the seal and water pump gaskets and move along.
As for the pump whine, if the reservoir is not the highest point of the system, you're going to get whine.
MuhThugga- Posts : 15
» Turbo Transaxle wanted
