LT1 Oil leak.
LT1 Oil leak.
Today i put the oil filter mount on with filter and began filling the engine with oil. I used 5 quarts of oil then i noticed oil pouring from the timing belt face plate the 2nd hole. I do have the water pump removed but wasnt sure if that could be it. Xschop thought maybe but was unsure. Here is a crappy pic just for reference.
[url=[You must be registered and logged in to see this image.]][You must be registered and logged in to see this image.][/url]
kelleysj- Posts : 194
Re: LT1 Oil leak.
Did you replace the plugs above the camshaft and the round ball bearing that goes in the hole under the main cap when you put the engine back together? What year LT1 is this?
laptop_geek- Posts : 230
Re: LT1 Oil leak.
I didnt put the engine together it was supposed to be a reman. Its an 1996 LT1 not real educated on the engine yet. I guess i will have to pull the plate off and get a good look. Has anyone ever ran into this?
Last edited by kelleysj on Thu Jan 20, 2011 8:58 pm; edited 1 time in total (Reason for editing : add to)
Re: LT1 Oil leak.
Why are you putting oil in it? If you don't have it fully assembled and in the car there really is no reason for it right now, You don't have to remove the cover to install or replace the seals, unless it is the front oil pan seal needing replaced.
Re: LT1 Oil leak.
IIRC, doesn't the WP shaft complete the seal on the LT's?
Re: LT1 Oil leak.
I just wanted to get some oil in the engine to keep it lubed up I was worried that it could rust in the damp shop i have it in. Im just curious if anyone knows what this is and what needs replaced.
Re: LT1 Oil leak.
I was told that maybe that was it just wanted to find out if that was the problem before i start putting things back together.
Re: LT1 Oil leak.
Before you put anything back together make 110% all the parts are there. There is also a waterpump inner splined COUPLER that drives the WP off the cam. Find a good schematic and confirm everything.
When I had an LT1 this place was the shizzle......
Re: LT1 Oil leak.
Thats the hole the opti goes in. The optispark unit completes the seal. Until you plug that in you have a huge hole for oil to pour out.
sbwrench- Posts : 66
Re: LT1 Oil leak.
Thanks for all the feed back fellas
LT1 waterpump
does it matter if you use the waterpump for the camaro or the vette.
Today at 6:58 am by Rob44
Today at 12:47 am by sharkey
