Radiator help
Radiator help
Hello. I have an LT1 swapped Turbo 944 that was built in 2014. That radiator sprung a leak the other day from somewhere between the fins. The coolant shoots out into the fan. I haven't taken it apart yet because I can't find a replacement radiator or should I say I'm not sure what to buy. Anyone have an idea what radiator I need or should buy? I may try to get the current one fixed but not sure if that's possible. Any help will be appreciated. I just read about the AFCO but it doesnt seem to have a drain.
nphd2000- Posts : 26
Re: Radiator help
The Afco option looks good. Drain valve is not necessary.
Also Lindsey racing, CSF, Wizard....
I am still running the original 1986 944 Turbo radiator with an aux radiator, where the intercooler was.
AFCO
Well I'm going to give the AFCO a shot. Should have ordered yesterday so it would be here for the weekend. I'll start the tear down tomorrow after work. May look into aux cooling as well
Today at 3:06 pm by Rob44
