electric power steering pump (volvo)
has anyone attempted to run an electric power steering pump on their swap? Specifically, I am looking into the Volvo S40 and V50 pumps from about 2005 to 2013. These are fairly common on mustang coyote swaps and some drift cars. I ran across one at a mustang show a couple of weeks ago and thought it would work well. I was going to try and fit it in the passenger front fender area and try and run the stock power steering reservoir with it.
Link from the corral on a swap:
Fairmont50- Posts : 8
Re: electric power steering pump (volvo)
I would be concerned about the electric pumps ability to flow enough and have correct pressure for both steering and hydroboost. But, it might work fine.
I installed a Vauxhall Astra pump on mine (not swapped, but big turbo). Pump worked fine, no issues at all about pressure!
There is an australian topic about it.
Dutch944- Posts : 4
I actually installed the volvo pump. I ultimately removed it. It seemed to not be enough for both power steering and braking.
I would have one or the other. If i braked first i would lose steering and thw same with the other. I ended up removing and going with the Mustang unit like others have.
Red944ls1- Posts : 98
I had purchased a VW Polo EPS pump for my V6 swapped 944. After reading this thread, the linked Mustang thread and a further linked thread in an EV forum I thought I would test the pump. It refused to show any sign of life so I obtained a Volvo pump.
I was intending to control the pump by speed through Canbus as the VW pump had that facility but I was always worried the VW pump would require some other instruction to make it operate.
I have just installed the Volvo pump and it works well with the BMW Mini steering rack I have installed. The turns from lock to lock are 2.3 and there does not appear to be any labouring. It does not have to also push a hydroboost as I have a remote booster for the front brakes.
The Mustang thread has details of a control unit that is available that can control assistance through either speed or a potentiometer. I will be using this unit to take speed from the ECU by Canbus to this control unit.
Happy I found this thread.
Jaffar- Posts : 2
Congrats on making it work. it seems to be a good setup if it works. For me the unit seemed to not have enough power for brakes and steering together. I do also have 6 piston brakes up front. I will track my car some day so i definitely need a consistent option
Yesterday at 8:32 am by Rob44
Yesterday at 8:28 am by Rob44
