Early 944 under dash wire identification help
EARLY 944 UNDER DASH WIRE IDENTIFICATION HELP
I don't have a wiring diagram for the early (square dash) 944s, but the only things on the console should be the roof switch, fog light switch, and rear wiper switch. The roof switch uses about six wires, the fog light uses four wires (I think), and I believe the rear wiper switch uses three wires. Without a wiring diagram for the 82 to early 85, I can't be sure. If I had to guess about a three wire harness going to the console with no place to connect, I would probably guess it goes to a rear wiper switch that might not be there because the car in question didn't have a rear wiper. Just guessing.
Hiroller- Posts : 3
Re: Early 944 under dash wire identification help
Those wires go to rear wiper or the power mirror switch on the center console. If you pull your ashtray out you will be able to see which switch they belong to.
JW1970- Posts : 39
Today at 3:06 pm by Rob44
