Depowered Rack - Hydroboost
I was hoping someone could point me in the right direction. I decided to depower my steering rack as I have been dealing with a leaking rack far too often and have had to replace it three times over the years. I assumed I'd be able to simply block off the high pressure line running to the rack from the mustang hydroboost so I could keep my brake assist...but apparently thats a no go. Now I am looking in a manual brake option. what do you think is the easiest way to do this to get me rolling. I hate to lose the hydroboost brakes but I dont know how to keep them with the manual rack
What is the best way to get back to running with manual rack.(depowered)
Red944ls1- Posts : 98
Re: Depowered Rack - Hydroboost
Run the high pressure line back to the reservoir. It won't be under any pressure, it just acts as another return line.
» Hydroboost without power steering rack!
» Fittings (AN) or (JIC) for LS1 pump, Porsche rack, GM hydroboost?
» PS Rack Question
» PS Rack Question
