How much power can a 016k transmission hold?
Getting all sorts of numbers here... thoughts?
ThomasJoseph315- Posts : 17
Re: How much power can a 016k transmission hold?
It depends entirely on your willingness/ability to baby it in low gears. I ran a 5p for 3 years with my 400 lb/ft LS1, no issues except wheel spin. This was all track lapping, doing good warm-ups/cool-downs with no hard launches or full throttle in 1st/2nd gears.
I upgraded to an AOR just for the LSD.
Third gear can't handle 400 lbs. ft. and slicks...
four_wheel_drifts- Posts : 6
016 is the base number for almost all 944 transmission. Need the 2 digit code on top of the bellhousing to determine which trans you have.
But, none of the 944 transmissions will hold up with 400lbs and slicks.
968 trans is much stronger, but i'm not sure how it will fare with slicks.
The Audi O1E is really strong, but harder to find.
four_wheel_drifts likes this post
I see posts from just a few years ago on various forums were members got the Audi 01e TDI FWD transmissions for less than $1000 shipped to the USA.
The good old days...
