» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
Which transmission would be the best?
Post  deathdealerdelta on Sat Feb 04, 2012 7:58 pm
Hello,
I have been told that the 944T tranny with an LSD is the best way to go when dropping a V8 powerplant into the 944 but I want to hear from people who have the LS setup in their 944. What has worked the best with the V8? Is it the 944T tranny w/LSD or are there other options out there? I had an idea about making enough space for a C5 tranny, bu of course there really isn't enough room. Any suggestions or ideas would be great.
Thank You,
Ray Russell
Fort Campbell, KY
101st Airborne Division
deathdealerdelta
trans C5
Post  kevin924kevin on Sun Feb 05, 2012 7:57 am
Hello, but there is enough room for the C5, mine is sitting in place, and it is in a 924. Good luck.
Re: Which transmission would be the best?
Post  docwyte on Sun Feb 05, 2012 9:25 am
Kevin, you've done a tremendous amount of cutting and fab work to get the C5 tranny to fit. It's awesome, but most people don't have the time, skill or $$ to make that happen.
OP, the Turbo tranny with lsd is fine, the only problem is it doesn't have a true overdrive highway gear like the C5 6th gear, so gas mileage on the freeway will suffer.
Post  deathdealerdelta on Sun Feb 05, 2012 9:33 am
I'm not too worried about gas mileage since I have had the car for about 8-9 months, changed the timing belt, balance belt and rollers and am now just at the 1000 mile re-tension point. I just want the best setup that will be reliable and I will never have to worry about it. Also I am tired of my 944 n/a always wanting to be in the highest gear. While on base the majority of speed limits is 25 and my car idles and cruises at 25mpg in 5th gear. It just feels as though I am in too low of gear until I get it to 5th.
deathdealerdelta
trans
Post  kevin924kevin on Sun Feb 05, 2012 6:49 pm
All i was saying is, they can fit.
Post  948 on Sun Feb 05, 2012 9:23 pm
Turbo trans, LSD, and an NA 5th gear.
gbox transmissions
Post  turbobob924 on Sat Apr 07, 2012 11:36 am
I saw some information on gbox being involved in some V8 midengine cars.
There is a 944GTRS car on their website. I wonder if they do any 944 transmission work or if one of the many other 911 transmissions could be adapted to a 944 setup?
www.gboxweb.com
turbobob924
http://www.turbo924.com
