Extended crank flange engines??
Has anyone used a extended rear crankshaft flange engine, like an early 6.0L LQ9 for a swap? Is there anything that may cause problems?? I understand the crank flange extends about 1/2 inch from the block, where the LS1 is close to flush.
Any advice?
Gordo.
...thinking of another swap......
Any advice?
Gordo.
murrayg- Posts : 105
