Silverado AC compressor conversion?
I was hoping someone could point me in the right direction. I have an ac compressor from the 2000 Silverado. I know that people have said that the variable pressure compressors will not work properly until it is converted to fixed. The compressors that I have seen converted are a little different than mine. Mine does not have a valve held in by a circuit. It has a wired sensor which I have attached a pic. How would I modify this compressor to work? All the links on the site seem to longer work but I do remember from years ago folks removed a valve that was held in. Again mine has a littlw electrical sensor i. The back.
The model compressor I have is a Delphi Hu6 for a Chevy silverado
Red944ls1- Posts : 98
Re: Silverado AC compressor conversion?
I received no responses however I did install the compressor as is and ac seems to be running fine. I installed new condenser and dryer. I fabled a new low pressure line I jumped the wires from the original porsche pressure switch to toggle the compressor on. I am assuming this compressor is a fixed pressure instead of variable like some others.
Hope this helps some others.
smkn951 likes this post
