Hood to throttle body clearance
Does anyone have pictures and the dimensions of where to trim the underwood reinforcement to clear the cable activated throttle body? I am going to put a new hood on my car and I want to trim it before I paint it.
Thank you, Gil
Thank you, Gil
gwistrup- Posts : 113
Re hood clearance
Thanks for the picture. Am I correct that you were able to leave the edges of the reinforcement intact?
Gil.
Gil.
Re: Hood to throttle body clearance
Yes. I cut at the support part's highest part from the hood surface. This gave me room to make the cut and left it some structural strength.
Here's mine! I made a small backing plate to "box" in the piece cut out.
murrayg- Posts : 105
Hood cut out
Did you glue in the plate? Could you give me the dimensions of the size of the cut and how far it is away from the front support that the hood latch bolts to? I really appreciate it.
Gil.
Gil.
Hood cut out
Here is what I inherited. Precision scalpel work.... (bought mine as a work in progress).
LS1 throttle body has been shaved a bit as well.
(First pics I have ever tried to upload... hope it helps ....)
Worryless- Posts : 13
Hood cut out
(Sorry... posting pics threw me for a loop)
Tape measure is 'hooked' onto one of the hood latch bolts.
RE- Hood to throttle body clearance.
Thank you for the information. Now I can trim the hood to the correct size and paint it when I paint the rest of the engine compartment.
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
